Old 02-29-2016, 04:02 AM
Ron61's Avatar
Ron61 Ron61 is offline
I think that he used to many and when he went around a corner hard it finally cracked the mounting and almost tore his wheel off as everything started to flop. Also he added his shims to the top where they had more room to move around. If he had put them on the bottom mount it may not have happened but some of the bottom mounts don't leave a place that you could shim. He finally took it in and had the mounts re-done and moved up some so they would work with the shocks and never had another problem.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
