Old 03-26-2016, 04:55 PM
stephen low's Avatar
stephen low stephen low is offline
Yes without your skills and equipment, I've had Marty on the case. He has previously done the same work for the FFR kits, very similar mods I believe.
Interestingly once I stood the car back on its boots I found I needed to wind the driver's side out 15mm to get a similar slight negative camber angle to the driver's side.
This was with the driver's side gear fully screwed in.
So am going to get Marty to shave off another 4 - 6 mm total off the driver side parts to give it a tad move adjustability inwards if ever needed.
Clearly the frame has some variance in it, the same as I found between sides with the bodywork and what I needed to open up to fit this gear.
By Friday I'd like to think the whole issue is sorted and that I'll have a car that tracks well for the moment.
slowy
