Old 04-06-2016, 08:09 PM
CR67rep CR67rep is offline
Cobra Make, Engine: Classic Roadsters Chevy 350
Originally Posted by Double Venom View Post
ADDENDUM TO THE ABOVE:
MODIFICATIOS NEEDED: NONE - BUT....
ADD EXTRA GROUNDS! 1 The gas tank sending unit, add an EXTA GOUND.
RON FRANCIS, PAINLESS, DAKOTA DIGITAL,CR'S, NONE INDICATE
A GROUND FOR THE FORD STATER SOLENOID OR VOLTAGE REGULATOR! ALL wiring kits are assuming a STEEL CAR! MAKE SURE YOU HAVE A "DEDICATED" GROUND(S) FOR EACH COMPONENT !
DV
DV- what is the need for and result of adding a ground for the sending unit? My gas gauge tends to get a mind of its own sticking on full often, is this solved by adding the ground you speak of?
