Old 04-08-2016, 10:32 PM
CR67rep CR67rep is offline
Cobra Make, Engine: Classic Roadsters Chevy 350
Default GM T5 bellhousing
Hello all, my CR is currently running a SBC with T5 trans. Apparently I have the bellhousing for a 3rd gen Camaro because my trans is mounted with the 15-20 degree "tilt" or rotation. Does anyone know of a bellhousing part number I could use to correct this and center up my shifter? My shift boot ring sits right on the curve of the trans tunnel (yuck). Starter is on the RH side and I have an externally mounted slave cylinder on the left. Thanks!
