Old 04-30-2016, 09:10 AM
Midcont Midcont is offline
Cobra Make, Engine: SPF-427R
Default How do i rotate shift pattern diagram to correct orientation
SPF with the Tremec 5 speed.
The shift pattern is turned 90 degrees and I'd like to straiten it out.
There are two small holes under the base where the stick screws into the knob, but there doesn't appear to be anything in there to loosen with an allen key.
I'm wondering if its just screwed tightly onto there and I just need to force it back the other way.
If that's the case, what is the best option to allow it to be tight in the correct positon?
Any assistance is appreciated.
