Old 06-09-2016, 04:32 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by taipan53 View Post
I have a 1966 FFR Mk III 351 W. My steering is really "twitchy" -- slight movement of the steering wheel at highway speed and BANG! I'm in another lane. I'm guessing that a change of rack and pinion gear ratios might be the answer. Two questions: Am I going in the right direction toward finding a solution to the problem? If this is the issue, any advice on where to go to get it adjusted or replaced? Many thanks in advance for your help. ~~ Skip
What is your FFR chassis number?
Which coil over shocks do you have (Gold, Silver, Red, and the brand)?
How many coils in the springs?
Tubular front A arms or donor Mustang?
What is your height set at front and rear?
Which rear suspension set up do you have? 4 link donor with donor mustang springs, 4 link with coil overs (again which color and brand, how many coils in the springs), 3 link, or IRS?
What rims are you using (diameter, width, offset if you know it) front and rear?
What tire size front and rear?
How old are the tires (there are date codes, Google how to read them)?
Finally, when was the last time the car was aligned?
We can start from there, the more details you can give us, the better chance of actually getting a response that will help you in the long run.
Bill S.
