Old 06-24-2016, 06:11 AM
patrickt patrickt is offline
Originally Posted by willtwallace View Post
I will not be swayed by peer pressure
... and you shouldn't be. But you owe it to yourself to just try out the QR hub while you're visiting. It's virtually invisible -- it's almost like a magic trick when you put your hands on the sides of the column, your finger tips seek out the hidden latch, and *poof*, like magic, the wheel just comes off like it was never attached at all.
Working under the driver side portion of the dash is 1000% easier with the steering wheel out of the car. Plus, you will find that you do not want your steering wheel to be positioned perfectly plum straight when you're driving down the highway. Doing that tends to block your gauges. You have to have a trial and error period to find exactly where you want your wheel, but having a QR hub on there makes doing that as easy as pie.
