Old 07-02-2016, 05:45 PM
lippy lippy is offline
If you are getting a new ignition box anyway, get a 6530. You can lock the dizzy and program whatever advance curve you want. You also can use a MAP sensor to give you more advance under light loads. An added benefit when you use the MAP with a wideband is that you can log vacuum, RPM, and AFR at the same time and really dial in your PV. MSD 6530 with MAP sensor
