Thread: Engine Dyno
Old 07-31-2016, 05:58 PM
spdbrake spdbrake is offline
It looks like if you shorten the Alt turnbuckle quite a bit down to 3-4 threads exposed at each rodend, you should have enough deflection to run a belt just to the alternator and the interference (Idler effect) of the water pump pulley would be enough to run it without slippage.
