Thread: Engine Dyno
Old 08-01-2016, 05:53 AM
DAVID GAGNARD's Avatar
Have you used this dyno shop before????
If not, call the operator and ask if you need the water pump on your engine and operational.......
The dyno shop I use down here does not use the water pump on the engine.........first time I used him had the front of the engine fully dressed,he took the water pump off and put an aluminum "plate" in it's place that his radiator hose hooked to and then another hose to the thermostat housing...
his machine has it's own water pump,so no need to have anything on the front of the engine past the timing chain cover.....
give him a call and see what he says.....
click on the camera icon under my name and look in my photo gallery, fist page,should be the third picture from the left,top row,you'll see my engine on the dyno and see what how it's setup.....
David
DAVID GAGNARD
