Old 09-21-2016, 04:10 PM
spdbrake spdbrake is offline
If you go the welding route stick with a professional. I've gotten bruises from turning a Austin Healey 3000 tank into a beach ball thinking a couple rinses and 50% water fill and argon running inside will make it safe.
The are some welding companies out there that can do the welding and most are not cheap as they sometimes use total immersion gas (room full of Argon or inert gas).
On BDR:
The tank is easy to drop out and the pump is external unless our running EFI.
Barring that you may give epoxy a shot 1st.
see the amazon link.
[ame]https://www.amazon.com/J-B-Weld-8217-AutoWeld-Repair/dp/B00R2CDUWE/ref=pd_lpo_263_bs_tr_img_2/153-6841469-4398557?ie=UTF8&psc=1&refRID=Z3SKVZSYJ0R5XAWBDBVP[/ame]
