Old 10-03-2016, 03:32 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
12 volt on the small terminal, operates the solenoid and meshs the pinion with the ring gear, BUT does not turn the engine.
We can leave it operated like this, to check the mesh depth of the pinion.
When you are happy with this, you then fit the heavy battery lead to the large terminal next to it.
Gary
