Old 10-04-2016, 04:47 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Gaz64 View Post
12 volt on the small terminal, operates the solenoid and meshs the pinion with the ring gear, BUT does not turn the engine.
We can leave it operated like this, to check the mesh depth of the pinion.
When you are happy with this, you then fit the heavy battery lead to the large terminal next to it.
Gary
And obviously, you disconnect the negative at the battery, before you fit the positive at the starter.
Gary
