It sounds as if you have a bad alternator? Have you tried swapping it out? Maybe you could try an upgraded one (I went with a high output chrome)
The trouble with these sorts of problems is that often you replace something like the regulator, but then it is immediately damaged by the (bad) alternator, etc.......so you may want to use a new regulator too, before you turn the key.
Hope that helps
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
