Old 10-13-2016, 03:25 PM
1795's Avatar
1795 1795 is offline
See if you can find a way to run some air ducts to the rotors, it will help cool them. Try to use the brakes as little as possible, quick hard braking and then off the brakes. You can also use downshifting/upshifting to transfer weight to the front wheels for turning. Another trick is to quickly taking your foot off the throttle, turn and then quickly accelerating to transfer weight to the front wheels and briefly slowing before turning during turns that do not require much braking. I would just caution you to attempt these techniques at slower speeds initially and only in corners with a lot of runoff in case you run into problems.
good luck
