Old 01-11-2017, 12:42 AM
KevinW KevinW is offline
Default Maybe I'm paranoid......
Originally Posted by KevinW View Post
Thanks for the suggestion, but I am always paranoid about putting anything onto the threads of fixings going into blind threaded holes for fear of building up pneumatic pressure. I spent a fair bit of time screwing in the bolts and unscrewing them and cleaning the threads to try and get them to go in smoothly - its all done now. Tomorrow is the moment of truth when I'll have some time to top up the coolant and see if it stays inside the engine!
OK, so I torqued both bolts up to 12 ft lbs, then to 15 ft lbs. Seemed OK, but then I noticed I have 1 coolant droplet drips every 6 hours, based on the large piece of card I put under the car to check for leaks. I am assuming that's still a leak (although I know FEs tend to leak oil)
Any suggestions? Tighten it some more ....or ?
I am running a spacer in there like this:
http://www.clubcobra.com/photopost/s...hp/photo/50573
so have a gasket either side, which I coated with Blue Hylomar. The bolts are extra length to account for the 10mm spacer, but still have 1-2mm depth clearance in the hole so they don't bottom out on the blind threads.
Crendon 427, in the making
http://crendonreplicas.com/
