Old 02-27-2017, 05:25 AM
patrickt patrickt is offline
Originally Posted by Dwight View Post
should the oil temp be 30 degrees above the water temp.?
I'm not going to offer up any numbers, but I will point out that the temperature of the oil and water is different in different locations in the engine. The temperature of the oil that is in contact with the underside of the piston is way, way hotter than the oil circulating around the temp sensor in the pan. So, if the desire is to "burn off" moisture and condensation, you can do that without ever having an oil temp reading anywhere near 212 degrees.
