  #95 (permalink)
Old 03-21-2017, 12:52 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Originally Posted by steve meltzer View Post
Starter out and, as the photos show, the pinion gear is a mess. You can see the shards of metal on the starter face. Will check the teeth on the flywheel this evening, if I have time. The guy at the electrical shop said this is a common Toyota Camry starter, with a different gear and different face. Good, strong and reliable starter. Wonder if it needed shims or some such tolerance issue?
That looks like a PowerMaster starter with their Infi-Clock rotation system.
There are internal shims for the starter face, to pull the gear away from the flywheel. I had to send mine back to PowerMaster and they installed a "special" second shim. The instructions say only to use one internal shim. I have the 9603 model.
Click here if image not shown
