  #97 (permalink)
Old 03-21-2017, 01:31 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
You need to measure the distance from your mounting plate to the front edge of your flywheel teeth. The long end if some dial calipers are great for this. It needs to be within 1/16" of spec, depending on your motor and starter model. If you're distance is under spec, you as the shim.
I'm a Family Practice doc in Ft. Worth.
Edit: Here are the instructions for your starter: http://www.powermastermotorsports.co...ockingInst.pdf
