Old 05-30-2017, 11:27 AM
Three Peaks Three Peaks is offline
Check out ebay. There are tons of them on there and you should be able to check out the pics to see if it matches up to yours. At the least, you can email the seller and ask questions.
I think most of the early 60's/70's 113A models are pretty much the same. Are you looking for the single speed or two speed model? The harnesses are different. With mine, I couldn't find a harness with the proper end on it so I used stak on connectors to connect to the wiper motor connector. Works great.
Bob
