Thread: Brake Booster
Old 06-15-2017, 10:16 AM
cycleguy55's Avatar
Originally Posted by jimbo01 View Post
Just to add to the information regarding the ATE booster. Upon sending the part to Karps for repair it was found that there was no check valve in the booster. It world be a great idea to check this. Talking with Karps they could not believe the fitting had no check valve in it.
Are you running an external vacuum reservoir and, if so, is there a check valve located there? FWIW, that's how my West Coast Cobra is set up, though I'm going to be adding a 2nd check valve on the booster, based upon the edited information below.
Edit: I just discovered references that indicate there should be check valves in both the vacuum reservoir (if equipped) and the booster.
Today's Technician: Automotive Brake Systems
5th Edition, Shop Manual
By Cliff Owen
Page 128
6th Edition, Classroom Manual
By Ken Pickerill
Page 128
Brian
Last edited by cycleguy55; 06-15-2017 at 11:41 AM.. Reason: Added reference information
