Old 07-02-2017, 09:57 AM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Originally Posted by Texasdoc View Post
Here is a good (but somewhat long) video on how the starter bending works.
YouTube clicky
Check the voltage at the starter. If it isn't getting 11+ volts, you may not be driving it fast enough to throw out (up) the bendix gear. If you know the starter is getting 12v and you hear the drive spinning, perhaps the bendix is stuck. If it works on the bench, you have 12v to it in the car, and it is seated flush on the block plate, I don't know why it's not engaging.
Measure how far your bendix comes out. Make sure you got a 9403 instead of a (potentially mis-labeled) shorter 9404.
Good starter dimension document
Doc,
Thanks for the links. I started watching that video yesterday, but gave up. After you sent the link and I got home, I watched the whole thing. You're right--it's good, but long. That instruction sheet is much better than what I found online or in the box with my starter. Heading out to the shop after another cup and hopefully will find and fix something easy.
AC
