Old 07-05-2017, 08:32 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
I believe the problem is with the builders installing them incorrectly. They should be powered and grounded directly from the battery. The battery acts a a filter for noise and voltage spikes. I might add that grounds are the source for the biggest electrical problems on fiberglass cars. Loose grounds, grounds to painted metal surfaces and oxidation at ground points due to moisture. Loose cheesy connectors and overloaded circuits are next.
SPFWiringDiagrams@Comcast.net
