Old 07-09-2017, 12:45 PM
Don Don is offline
Redhawk......thanks
Neither of the two vendors I spoke with mentioned a moisture test. The concrete garage floor is new construction and poured the beginning of May. Mentioned also was the standard curing/setup time of 28 days. Concrete poured over a vapor barrier.
Is this a typical moisture test kit:
http://www.homedepot.com/catalog/pdf...4a67b5418a.pdf
Moisture/Alkali Test Kit - Home Depot
The Calcium Chloride Moisture Test Kit measures the quantity of moisture passing through the slab, on and below grade concrete floors (lbs. of moisture over a ...
Have seen reference to a home test of 2' X 2' plastic film duct taped to the floor and determine after a few days if there is moisture/water droplets within the taped film. Valid test or ?
