Old 08-10-2017, 07:11 PM
patrickt patrickt is offline
Originally Posted by dcdoug View Post
You don't think I'd be even more under-cammed if I did that?
You and I have the same cam lobe profiles, but your LSA is tighter. With my 4.125" stroker SCAT, and a slight increase in bore, I'm at 447 CID. I absolutely love my cam and wouldn't change it. A stroker crank in your block is going to be a few cubes larger than mine, but not a whole lot. Now, a new SFT cam, cut to your specs, is only a couple of hundred bucks, so it's not a big deal. But I don't think I'd go with a 428 crank and then internally balance it -- I'd just go stroker. Now, I'll vote for the 4.125", but most people around her will say go with the 4.250".
