Old 09-22-2017, 02:32 PM
cycleguy55's Avatar
I'd say page loading is glacial - much slower then it had been.
I just ran a test that loads a fresh view of www.clubcobra.com 3 times. Site location of the test facility is From: Dulles, VA. https://www.webpagetest.org/easy.php
Results:
  • Average time for the page to load 100% was 38.0 seconds. (38.0s, 37.5s, 38.5s)
  • 'First View' times were listed as 35.504s, 34.165s, and 36.117s
  • 'First Byte' time rates an 'F'
  • 'Keep-alive Enabled' and 'Compress Images' were both rated 'A'
  • 'Compress Transfer' and 'Cache static content' were both rated 'B'
  • CC is making 'Effective use of CDN' (Content Delivery Network)
The results can be seen at WebPagetest Test Result - Dulles : www.clubcobra.com - 09/22/17 20:50:28 - including the ability to get more detailed information (e.g. Details, Performance Review, etc.)
The problem is clearly in the time it's taking the server(s) to respond to requests. Once the data starts flowing it's reasonably good. The big question is "what's the root cause of the time it's taking for the server(s) to respond?" Find and fix the root cause and the response time problem probably goes away.
Brian
