Old 10-06-2017, 06:09 PM
DanEC's Avatar
DanEC DanEC is offline
I would recommend getting ARP fasteners also. I don't believe washers or lockwashers are used under the flywheel bolts. Some blue (medium strength) threadlocker is a good idea to use on the bolts. It's provides some additional security but doesn't take a heating torch to break them loose later.
I know on Chevrolets a crank dowel is not used on most engines - the crank dowel hole is actually an indexing provision for machining and drilling the crank. Not completely sure about Fords but pretty sure my stroked 428 didn't use a dowel.
ERA 782 Running
