Old 10-10-2017, 02:56 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by AC Ventura View Post
Thanks guys
Seems as suspected, external slave and fork if possible. If not Tilton, perfect line up and clutch pedal stop.
I have new FE/Quick Time RM 6057/ short shaft 600 TKO + McLeod 12” Street Pro, awaiting installation, once the current engine comes out.
Can anyone please suggest an off the shelf, aftermarket clutch fork and slave cylinder that is intended as a bolt in for this set up?
Someone here has a kit that fits into a Quicktime bell housing. I think it is Mike Forte. If it isn't someone will correct me. It's the one I used on mine and I loved the feel of the clutch afterwards.
I have a list from the guy that installed it:
Parts required: External slave kit
Clutch fork
Release bearing
Adjustable fork pivot ball
Tremec trans. front bearing retainer
13/16 Master cyl. to replace current 3/4
Like I said I'm pretty sure he got the stuff from Forte after I got them together but my pack-rat email doesn't show it since I just got them together for it. Note the change to the master cylinder...
Tony
CSX4005LA
