Old 10-31-2017, 03:20 AM
blykins blykins is offline
I can machine a block for you, get the rotating assembly here, and do all the bearing clearance checks/adjustments for you. The majority of the work in putting a SBF short block together is making sure the bearing clearances are correct and making sure the rotating assembly clears the block.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
