Old 12-12-2017, 10:06 PM
spdbrake spdbrake is offline
Originally Posted by Jaydee View Post
It looks like a resistance problem. The connectors become corroded and resistance causes the heat then it just snowballs from there. Coat your connectors before connecting them to prevent this. JD
I think you're correct Jaydee. Either corroded, pushed back pin(not seated and locked) or loose connector.
The burn is in the connector.
