Old 01-08-2018, 12:53 PM
cycleguy55's Avatar
Originally Posted by bobcowan View Post
Body roll is not necessarily a bad thing. Changing sway bars will change handling characteristics, specifically under and oversteer. If your car is pretty neutral right now, and you add a significantly larger front sway bar, you will most likely develop oversteer.
How Sway Bars Work and Why You Should Care | Speed Academy
If you just want to eliminate body roll, you might want to consider increasing springs rates. Especially if you're getting a lot of nose dive on hard braking.
How's your transient response? On a quick left right left, does it seem to wallow or get tail happy? If it does, that would be another reason to consider better springs.
Increasing the size of the front bar or adding one will increase understeer, not oversteer.
To increase understeer: Add or increase the size / stiffness of the front bar, reduce the size / soften or remove the rear bar, or a combination of both.
To increase oversteer: Add or increase the size / stiffness of the rear bar, reduce the size / soften or remove the front bar, or a combination of both.
Brian
