Old 05-28-2002, 11:39 PM
Snake Snake is offline
Post DV...Need your HELP!!
Jim was talking aout this....The wiring set up for the electric fan has been troublesome as I have heard of several other CR cobra owners having the same troubles. Again DV can help you with this. I ended up dumping the thermostat control that came with the fan and purchased one from Jeg's that actually has a thermostat that fits into your radiator drain. I then has a relay with a control knob that you can attach to your frame. This is a much better setup that I used at DV's recommendation.
What I would need from you is a part number for the thermostat that fits into the radiator drain and I guess a relay. Also some help in conecting this all up...all I got is the fan from CR...I got it from the guy I bought the body from.
Thanks DV.
Snake.
