Old 03-21-2018, 02:45 AM
mln385's Avatar
mln385 mln385 is offline
Cobra Make, Engine: BDR
Originally Posted by chrisd0729 View Post
Just tried turning the bolt and it's in there super tight, not budging. The car is on the ground with full weight on the tires... if it was loose/broken in there, would I need to take the weight off the tires and free up the rear suspension to turn it?
Check out the 2 pics below, looks like a sloppy blue mark on the bolt so I'm not sure if the bolt turned since the original install?
The picture shows the bolt as been moved from factory mark, either tightened or serviced at some time.
The pictures make your bushing look torn? Is it? If so that may be the issue the play in the bushing, take a pry bar and move housing up and down does it move?
