Old 05-30-2002, 08:52 AM
Snake Snake is offline
Post DV... Need help .
Jim was talking about this problem?....The wiring set up for the electric fan has been troublesome as I have heard of several other CR cobra owners having the same troubles. Again DV can help you with this. I ended up dumping the thermostat control that came with the fan and purchased one from Jeg's that actually has a thermostat that fits into your radiator drain. It then has a relay with a control knob that you can attach to your frame. This is a much better setup that I used at DV's recommendation.
DV...do you have a part number for the thermostat that fits into the radiator drain and, does the relay come with it?
Also some help in conecting this all up...all I got is the fan from CR...I got it from the guy I bought the body from.
Thanks DV.
Snake.
