  #37 (permalink)
Old 04-17-2018, 07:14 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
If compression allows, I always grind a lot of advance into my street cams. The throttle response and snap is very much noticeable.
Most of my 110 LSA cams end up on a 104 ICL. My 106 and 108 LSA cams will usually end up at either 102 or 100 ICL, if the piston/valve clearance and the compression ratio will play nice with each other.
Yes, I'd like to try that combo one day soon with the next combo of 410+, no hints yet,
