Old 06-02-2018, 07:24 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
old thread but
several of us have been using Pennzoil because is 1/3 the cost and ease to find.
I found this online:
PennzoilŪ Synchromesh Fluid is designed to offer optimal protection for moderately loaded gears in manual transmissions. Containing a high detergent additive system, it helps cope with water, dust, dirt, and any other small deposits you might encounter on or off-road1. PennzoilŪ Synchromesh Fluid also offers synchronizer compatibility for performance in manual transmissions, specifically to fulfill the needs of Chrysler, GM, Honda and other transmission requirements.
PennzoilŪ Synchromesh Fluid meets General Motors specification 9985648 for use where GM part numbers 12345349 or 12345577 are called out for use. Chrysler manual transmission fluid specification MS-9224 is also met. This high quality manual transmission fluid is formulated for good low temperature flow to maintain shift characteristics even after a cold night2. Corrosion protection is added to help protect your transmission.
