Old 06-06-2018, 07:37 PM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by crendonman427sc View Post
Hi Glen,
Surely the Canton Oil Pan would hit something first, before the flange of the Scattershield hit if they were that low??
I am trying to figure this out in my head (before I commit to buying a certain type or model) but Technical Dimension Drawings from manufacturers, seem to be fairly thin on the ground.
David
Hi David,
It should be a simple enough check to measure the distance from the flywheel to the block/pan interface, and then add on the depth measurement of the Canton pan (if it's not fitted), and compare that summation to the outer radius of the scattershield. I would do that myself (Canton pan and QT scattershield) ...but would have to move too much 'stuff' in my limited garage space
Glen
