There is a ring inside the trunk that the screws on the topside of the cap assembly attach to. The cap assemble my have been waterproofed with some silicone to the fiberglass. As I recall I disconnected the filler hose inside the wheel well to remove the cap assembly from above with a small length of hose connected to it.
When you reassemble, be sure to seal the cap flange to the body with some silicone or the recessed area on the body for the cap assembly will collect water and it will drain into the trunk.
I might have photos at home. I'll check after work.
Blas
SPFWiringDiagrams@Comcast.net
