Old 08-09-2018, 06:51 AM
nniets's Avatar
nniets nniets is offline
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
Originally Posted by Danr55 View Post
Looks like Cleveland valve covers. Did the boss 302 have offset valve
The Boss 302 heads were essentially Cleveland heads fitted to the Windsor block. Cleveland heads will bolt to a Windsor block but it requires a special intake manifold.
If you look at the close up of the carburetor, you can see something grey just below the valve cover - I think that's a spacer/adapter to make the Boss valve covers fit a Windsor head. Also, if you look at the header side of the the valve cover, it seems to hang out over the headers and header flange quite a bit. Another thing: Boss intake ports are larger and more rounded than the Windsor; those just look like regular 289/302 intake port shapes to me. I think someone wanted the panache of a Boss 302 without spending the big bucks.
I haven't fooled with the Boss parts in nearly 40 years, so I'm a little rusty on ID.
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
