Old 08-09-2018, 05:01 PM
nniets's Avatar
nniets nniets is offline
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
Originally Posted by MKS427 View Post
I was told the Cleveland blocks were completely different and the parts didn't interchange. Do the Cleveland heads fit on a 302 or 351W?
Cleveland heads will bolt on to a Windsor block (and vice versa, but why would you?) but there are water passage issues. The issues have work arounds that aren't too horrible. The biggest issue as I recall was getting an intake to fit. Several manufacturers now make such manifolds but they're about double the cost of your basic Edelbrock.
The blocks are definitely different (main bearings, deck height, oiling configuration, etc...) but that didn't prevent the head bolt pattern from being the same. I suspect that Ford was using a 302 to prototype the Cleveland head design and someone said "Wow! This would be a beast in Trans AM!" The tunnel port 302 was sort of a dud with a narrow rpm band.
Again, its been 40 years, I'm probably off base on something, but not much.
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
