Old 08-10-2018, 02:07 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Here's the photo of how we mounted the Weldon Pump on rubber Isolaters on the side of the Tunnel to tuck it out of the way yet make it close enough to plumb the Pump/Filter/ Cooler.
Here's the input and mounting bracket for the filter.... You will notice since we mount sending units with teflon we have to use safety wire to ground the sending unit to the chassis. No they don't ground themselves thru the NTP....
Then on the output side of the Filter we turn the output around and head back to the input side of the pump... notice the the level of the Transmission Fluid is above the pump and that makes it easy on the pump as the fluid is all ready at the input level of the pump when activated and the pump does not cavatate with any air in the lines.
Morris
