Old 08-11-2018, 01:54 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Stephan
I forgot to tell you the temperatures .... I can't say what the temps are without the cooler.... but when we run the first 2 laps it runs around 180*degrees and that's warming up .... when we go up to speed ...the temp goes up with the cooler up to 195*degrees and stabilizes there.... I would say without the cooler it probably is running around 205*-225*degrees which we feel is to high.....plus the shifting is fine .... but we grab the bottom of the shifter to move it..... for some reason with your hand low on the shifter it likes it .... if I shift at the top where the Delrin knob is ...it seems to want to grind the gears....
so we just shift lower on the stick. I think that on the top of the stick ... you just have to much power and start forcing the gears in stead of letting them mesh like they should be... Liberty told me to just use it.... and we did... after the first run the filter was quite dirty .... but now it's clean.... when we check it ....
Morris
