Thread: Valve seals
Old 09-23-2018, 01:07 PM
HTM101 HTM101 is offline
Originally Posted by classical glass View Post
I really don't want to pull the heads I would like to install them on the car. I purchased a valve spring compression tool that will slide over the rocker shaft. I have installed seals on GM motors before so I know the basics. My main question is what is the best way to index the engine so both valves are closed. I do have a air pressure spark plug adapter tool to keep the valves closed when the valve springs are removed.
Thank
I replaced all springs, locators, retainers, locks and seals on my engine a few weeks back. PM me if you'd like, and I'll be glad to help with your questions.
David
