Old 01-24-2019, 01:38 PM
tortuga tortuga is offline
Default New THICKER Gaskets to Slightly raise the Manifold...
Originally Posted by hauss View Post
Not sure what you did hope you removed manifold and sealed it properly otherwise you will be back trust me. Try the right stuff from permatex and new intake gaskets.
[quote=tortuga;1457172]As several pointed out, my intake was not clamping down due to ever so slight interference at the China walls. Instead of machining I installed a set of Cometic 0.120 thick intake gaskets which matched perfectly with my super victor intake ports, (which are a tad smaller than the ports in the head...which if matched would yield a bit more power I suppose, but I’m fine where it’s at) so far oil hasn’t dropped a bit!
Used Ford Recommended Silicon Sealant (Permatex Ultra Black).
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
