Old 03-19-2019, 12:29 PM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Originally Posted by kevins2 View Post
The 3rd tail light is a good idea, but if you haven't upgraded to LED tail lights, that's a major safety improvement that I'd suggest first because it's so easy to do. I recommend the bulbs from Superbrightled.com. The cost of these bulbs has come down substantially so no reason not to use them. Be sure to get the red LEDs. They are bright even in direct sunlight and looking at mine makes me squint from the brightness in low light. I left the 1157 bulbs in the front so had no problem with the flasher working.
Kevin
Kevin,
Absolutely agree! I ordered the 1157 replacement bulbs (and ballast resistors just in case) this morning. I ordered 4 just to have spares as I'm I'm most concerned about the brake lights, not so much the front signal lights. If there are no issues I can always add the front (thus the ballast resistors).
Evan
