Old 04-27-2019, 05:54 AM
Unique427 Unique427 is offline
Originally Posted by undy View Post
If you like to fish and have a boat with 50' of extra nylon line you could... J/K. As mentioned, the heads are nothing special run of the mill FE heads. You'd have to spend a ton to get them to support 500hp (porting, guides, valves etc). You do much better just buying a set of Edelbrock aluminum heads (or others) and call it a day.
I was faced with a similar circumstance to use modified cast iron heads
or go the more expensive route of ported/polished Edelbrock aluminum heads.
Went with Edelbrock and never looked back. Way better flow/power.
Also dropped 60 lbs. off the frontend (Ford Racing A460).
Buy once cry once.
