Old 05-12-2019, 11:05 AM
patrickt patrickt is offline
Before you do that, try my first suggestion of running a clean, fused, 12v+ to the "I" terminal of the voltage regulator, all with the fuse removed and the original wire to the I terminal cut. This effectively bypasses the ignition light. If the system then charges properly, then the short is back on the green wire somewhere upstream of the fuel gauge.
