Old 05-12-2019, 05:28 PM
DanEC's Avatar
DanEC DanEC is offline
Evan - you can remove the steering wheel, loosen the brackets holding the steering column to lower it as much as possible, wrap the column to protect the finish, and remove the screws holding the panel and lower it to where the column will support it. Just don't completely unscrew the column bracket - lower it as much as possible. There are so many cables, wires, etc connected to it that it won't go anywhere. Then as Patrick said you can access it from the top.
Wish I could help more on the root issue but Patricks on the case so he will get it figured out - I have confidence in him.
On the broken visor - don't sweat it - gives you a reason to order those from Finish Line with the gold Cobra label like the originals.
ERA 782 Running
