Old 05-17-2019, 08:29 AM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
[quote=patrickt;1461837]
Run a fused wire from the ACC terminal of your ignition switch (WHITE wire) to the exposed pin on the ignition switch that had the two green wires on it. The G/R wire should still be attached to the ignition light normally.
I assume you mean the exposed pin on the ignition light not switch?
