Old 05-17-2019, 08:44 AM
patrickt patrickt is offline
Originally Posted by ACHiPo View Post
I assume you mean the exposed pin on the ignition light not switch?
Yes, that was a typo.
Talked to Bob. I am going to modify the VR connector to emulate the older design with out an ignition light, removing the "I" wire from the connector and jumpering "A" to "S". I will reinstall the fuse (which may blow again) so maybe I'll regain the use of my tach. Even if the fuse blows, I should be able to drive the car and have it charge (hopefully)!
Alright, that's pretty easy to do and we can always switch it back.
